Delete old RAID 5 entry in Settings>Storage
As the picture shows I’ve got an old RAID five entry in my Settings>Storage window. I’ve been looking for an mdadm.conf file through the terminal to remove the entry from the Storage window.
Can someone point me in the right direction?
Regards
Antonio
Hi Antonio,
You will need to login with ssh then run these commands…
cd /var/lib/casaos/db/
# Back storage db
sudo cp local-storage.db local-storage.db.bak
# List raids
sqlite3 local-storage.db "SELECT * FROM raids;"
# Shown db structure (optional)
sqlite3 local-storage.db ".schema"
CREATE TABLE `o_disk` (`id` integer,`uuid` text,`mount_point` text,`created_at` integer,`is_deleted` integer,PRIMARY KEY (`id`));
CREATE TABLE `raids` (`id` integer,`name` text,`uuid` text,`uuids` text,`path` text,`mount_point` text,`level` integer,`shortage` numeric,`devices` text,`serials` text,`is_default` numeric,`disk_number` integer,`reshape` numeric,`dev_size` integer,`status` text,`members` text,`fs_type` text,PRIMARY KEY (`id`));
# Delete raid entry by <id> Replace 99, 100 with one or more ids NOTE: The id column is first.
sudo sqlite3 local-storage.db "DELETE FROM raids WHERE id IN (99,100);"
# Reboot
sudo reboot
Thanks mate, that was exactly what I was looking for. I’d been looking for fstab files and what not, this did the trick.
Regards
Antonio
