Delete Backup on dashboard and ZimaClient
I have created a backup through ZimaClient, but this backup does not start.
I want to delete this task, but there is no way how to cancell it, not in ZimaClient, not int ZimaOS dashboard.
Help, please,
Please state your ZimaOS and ZIma Clinet version number first, and if convenient, please record a short video. Thank you.
Thanks, Zima OS v1.6.2 ZimaClient 2.3.2
There is no way to cancell this backup. Thanks
Sorry, I can’t see the video you posted. Alternatively, you could create a YouTube video link and set it to be viewable only via the link. That way, I can see the specific phenomenon. Thank you!
HI, I think I’ve solved it. I have uninstall the ZimaClient, clear temp files in my pc, and then reinstall ZimaClient.
Once the backup is created, i can cancell it, and it will be cancelled and disapear from the task and dashboard.
The problem I’ve encounter is that the backup doesn’t back files from the LAN.
I have the work network 192.168.1.xx ZimaBoard is on Lan 192.168.20.xx but when I create the backup in ZimaClient does not backup the files. May be is because i don’t have enough privileges to do it?
Cheers,
