Default Immich Machine Learning Brocken
Hi, In the default Immich Version in ZimaOS machine learning does not work because the ML server is not known:
In the setting go to immich-server-v2
There add the variable IMMICH_MACHINE_LEARNING_URL with the value: http://immich-machine-learning-v2:3003
I just spent all of last night fighting with Immich V2 to learn this was the problem about 1 hour before you posted it. Got ML running nicely and then decided to take a look what was new on Icewhale Community, and here is the answer!
