Whatever the kind of filsesystem you’re using, this is a Nextcloud question and you can indeed encrypt things but there are two different cases :
You have ultra sensitive data and might want to set up server side encryption (SSE) ;
Or you just need to protect some folders so that only you and/or those you trust can access this content, then you need to enable the end-to-end encryption module (E2EE).
thanks @jme69 .
i 've just installed the E2EE security protocol .
like i got blocked with my own cloudflare security , i wait for tomorrow to go further .
No idea what cloudflare is thinking, maybe they should mind their own business… But anyway, you really need to take care about two things before encrypting anything :
Make a backup of all your data before activating the extension ;
Initialize E2EE consistently across all your connected devices with the same mnemonic.
Yes, I completely agree (the same goes for Cloudflare).
Since I’ve set up fairly restrictive security protocols to prevent any malicious activity on my sites, I often get flagged. All it takes is a slightly higher connection volume, and boom! “Rate limited.”
Anyway, back to Nextcloud.
I figured out how to enable the E2EE protocol since it wasn’t enabled by default.
I suggested two solutions to my colleague, since I’m responsible for what I host on my NAS:
Either E2EE with Nextcloud
Or Cryptomanor (suggested by Claude AI), which would also use Nextcloud for storage but would encrypt the data independently on his computer before transferring it (at least, that’s what I understood).
Unfortunately, in either case, if he loses his key, he loses everything.
And he’s not ready for that yet—he’s still thinking it over.
