DAS Drive not remounting after removal
I powered off my Server running ZimaOS v1.8.0 & unplugged my DAS So I could reformat two new drives with windows. When I reconnect my DAS the drive I was using is no longer recognized & I am only prompted to create new storage.
I connected back to windows using DiscGenius and all of my files are still there but the drive is listed as damaged.
How can I reconnect the drive to my server?
Thanks for your feedback. Please first run `curl -fsSL https://get.casaos.io/diskinfo.sh | sudo bash`,
then locate the `diskinfo.log` file in the “Files” section and send it to us(dina@icewhale.org). Thank you!
