Custom widget proposal
Hi, I searched but did not see this feature request come up prior.
also I’m not 100% if this is the forum category to post this is, apologies in advance if not.
I would like to request a feature to add custom widgets on the zimaOS home page.
for MY use case, i want to add a diverse group of widgets, example:
  • weather
  • pomodoro integration
  • add quick memos widget and see pinned memos
  • see usage stats
  • quick pihole toggle
  • ai (webui) quick chat box
All these above are different docker containers I have running in zima, and I wanted to have aspects of each in one place and I was thinking to accomplish this, the easiest way would be to allow users to add a widget on the left, that supports custom html/css/javascript OR a widget that requests an endpoint and displays the response, and polls every x seconds.
Included is a screenshot of where this proposed widget type can go. If you would like a mockup in photoshop of this concept, I can provide that easily.
Let me know what you all think about this. Personally, customization flexibility is the only thing I believe is missing from this great OS.
Thanks but I was hoping there would be a native version rather than another docker container, its easy to write my own dashboard from scratch actually.
