I have three issues, but I will list them seperatly.
In install of ZimaOS on older Intel server.
Intel(R) Xeon(R) CPU 5110 @ 1.60GHz
2 Cores1.60 GHz4 Threads
31.3 GB total DDR2
Advanced Micro Devices, Inc. [AMD/ATI] ES1000 (rev 02)
Coral USB Edge TPU
Question: Should Coral show up in the Deivce Info?
It is in stalled and tried it on both the USB 3.0 internal on the server and an added PCIe USB 3.1-3.0 card.
Is there drivers to install it on ZimaOSv1.5.4 ?
My plan is to use it with Frigate for Security cams detection, all my cams or Onvif, H264 or H265 so no decoding GPU required. I install OS with the Coral connected, I don’t see in the lspci in terminal or anywhere in the GUI.
