CoolStore is not working any more
In the newest beta the Coolstore could not be added anymore because the json file is missing.
How about the apps that I’ve installed via this store? Is it possible to update paperless-ngx for example? And how does this work?
@knakrack Is Coolstore the source of the app store you maintain? Do you have a github repository address or author’s contact information? You need to contact the author to build the data of the v2 application store source.
I’ve contacted the author via github. Hopefully this will help.
