Controllable RGB - how do you control it?
I find no documentation on this cool feature. How do I control the RGBs? Wi-Fi/Bluetooth/ZimaOS/iOS app?
I would love to be able to control these streamlined RGB lights for the seventh bay, even if I am using TrueNAS Scale as the OS
there is literally a post directly above yours that tells you how to do it :slight_smile:
Unleash the ZimaCube: Introducing CubeFX, the Open-Source LED strip Firmware - ZimaCube - IceWhale Community Forum
Thank you very much for your interest in this. We plan to open source this document on the official website docs interface this week. Thank you for your support!
I would prefer not to flash the ESP32 with custom firmware - how is it supposed to be controlled from the OS, BIOS or Wi-Fi? Both for those using CasaOS and other OSes?
then you will have to wait until their is an official app to do that (they will be publishing an API
the ESP is controlled via ZimaOS over wifi - that’s what the wifi module on the motherboard is used for, to communicate to the board. I believe when the API is released CubeFX will still support control of it from ZimaOS too.
sounds like you need to wait - there are lots of features for ZimaOS comingn over the next few months.
