Container does not recognize external disk
I installed qbittorrent and jdownloader on CasaOS and I have a physical disk configured in the same VM via fstab, but when I redirect the path to the download folder, an access denied error occurs according to the logs. I have already tested it in another folder on the same host and it only works on the external disk, giving the error. Does anyone know if there is a parameter for the containers of the same disk to start as root?
Note: I can only write something to this external disk when I am logged in as root in the system terminal.
