Hello, i have a NUC Fujitsu Esprimo Q920 MPC2, it have a Intel Core I5.
I installed ZimaOS on the SSD, it appears on the Boot menu but when i selected it appears the message “Reboot and select proper boot device or insert boot media in selected boot device and press a key”
I installed then the SSD externally in a laptop and ZimaOS loaded perfectly.
Could this by a compatibility issue or there is a way to make this work?
Thanks!
