CasaOS+Tailscale: Seamless Home Network Integration + Remote access to your data
Tailscale is now on the CasaOS shelf!
Here’s what you can expect:
1. Easy Setup: Learn how to effortlessly establish an encrypted and secure virtual LAN, allowing direct device-to-device communication without exposing them to the public internet. No complex server setup or port forwarding required!
2. Simplified Configuration: Discover how to download and use the Tailscale application, making it a breeze to connect to your home network. No specialized networking knowledge needed!
3. Multi-Platform Compatibility: Explore how different devices from various platforms can seamlessly join the virtual LAN, ensuring secure access among all your devices.
4. Remote Access Made Easy: Find out how Tailscale enables you to securely access CasaOS devices and services from anywhere using your mobile devices, ensuring you stay connected even when you’re away from home.
5. Fast and Stable Connections: Learn about Tailscale’s high-speed, low-latency virtual LAN connections, offering a more reliable mesh networking solution.
6. Enhanced Security: Discover how access control allows you to selectively enable services, ensuring a higher level of security for your home network.
Like, share, and subscribe to our channel to stay up to date with the latest technology trends and solutions for your smart home network. Let’s build a connected and secure future together!
This is great to see! So I understand it allows you to connect to CasaOS dashboard using authenticated devices using tailscale app. Are you also able to access the containers on CasaOS remotely?
I have a webui for another application running on port 90 so should be able to access that too?
