Good morning. The ttual version of casaos on my zimablade is 0.4.8, but the OS is debian bullseye. If I upgrade to bookworm is it possible that casaos no longer works? Thank you for your answers
I solved it by editing the file “/etc/apt/souces.list” and replacing the entry “bullseye” with “bookworm” after giving a “sudo apt update && sudo apt upgrade”. After saving the changes to the file I gave it back. “sudo apt update && sudo apt dist-upgrade”. Rebooted with the new version. All ok.
