Can't connect to preused Zimaboard
hi guys,
I’m new in the field zimaboard. I got a used zimaboard off eBay and can’t set it up.
the standard user with password does not work. I cannot reach the client via “cases.local” or “https://192.168.178.30:8006/”.
Can I reset it to factory settings?
Yes, you can. ZimaBoard CasaOS Factory Recovery | Zimaspace Docs
We also suggest you experience ZimaOS on ZimaBoard: How to Install ZimaOS | Zimaspace Docs
The above tutorial applies to ZimaCube and also ZimaBoard.
