Can i reinstall on proxmox
hi i need to reinstall zimaos but this time i would like to install it on proxmox 9 can i use the same pc and the license i have?
i’m not changing the pc just the method i’m using it
  1. system specs
  2. CPU AMD Ryzen 7 PRO 8845HS w/ Radeon 780M Graphics
    8 Cores3.80 GHz16 Threads
    1 RAM 30.7 GB total 4800 MHz DDR5
    drives used
    3-2tb raid5 and 3-6tb raid5 1-128gb m.2 boot disk 1-2tb m.2 part of 3-2tb raid5
