Hello, everyone! I would like to leave a review about this system because, after switching from CasaOS to ZimaOS, I was unfortunately not very satisfied.
I found many drawbacks and bugs
The computer application. It works strangely. I mainly use it on macOS, and it works like this: sometimes after a while, it kicks me out and then asks me to enter my password. Okay, I enter my password, but the drives don’t connect. Sad. It periodically kicks me out of my account, and it has limited functionality.
Containers. They work as they please. Installing applications from the store was particularly problematic. If the installation did not go according to plan, the application installation would hang indefinitely at the top. Logging out of the system and restarting the browser does not help; only restarting the system saves the day. I recently installed V2raya for traffic proxying, and all my containers that worked with the bridge network simply stopped opening. I don’t know what the reason is yet, but the solution will be to install another system.
Translation. I use the Russian language, and it’s terrible. Not only is the translation poor, but the font is not very good either.
Closed OS. It is not possible to have full control over the system, nor is it possible to install third-party packages directly on the system (I, for example, need this capability).
Closed ZVM. It is not possible to pass devices from hardware to a virtual system, such as mice, disks, and other devices. The network behaves strangely. If I set one mode, the machine ends up on my local home network; if I set another, it ends up on the internal network. The network does not have access to network folders on ZimaOS.
I did not like how the backup system works; it just copies files to the desired disk and that’s it. Come on, they could have added archiving and at least password protection. I’ll have to use duplicati.
Flawed system monitoring with built-in btop/ttyd tools. They just don’t work. I open the monitoring panel through the ZimaOS main panel, and nothing is displayed in the tab, even though it opened and the name is displayed in the status bar.
Update: Item 7, system monitoring. After updating to version 1.5.2, monitoring works correctly.
