Bug Report: False CPU temperature reading (100°C) on Ugreen DXP4800
Subject: Bug Report: False CPU temperature reading (100°C) on Ugreen DXP4800 Plus
Hi everyone,
I’m running ZimaOS on a Ugreen DXP4800 Plus NAS, and I’ve encountered a sensor reading bug regarding the CPU temperature.
Even when the CPU is completely idle (verified via top and confirmed by checking the physical temperature of the unit, which is completely cool to the touch), the sensors command reports a constant 100°C on the coretemp-isa-0000 package and cores:
Plaintext
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +100.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:       +100.0°C  (high = +100.0°C, crit = +100.0°C)
Core 8:        +91.0°C  (high = +100.0°C, crit = +100.0°C)
Core 9:        +91.0°C  (high = +100.0°C, crit = +100.0°C)
Core 10:       +91.0°C  (high = +100.0°C, crit = +100.0°C)
Core 11:       +91.0°C  (high = +100.0°C, crit = +100.0°C)
It is clearly a false positive / offset reading issue specific to this hardware under ZimaOS.
Would it be possible for the development team to look into this hardware compatibility issue or add a fix/patch in a future update to correct the sensor readings for the Ugreen DXP series?
Thanks for your hard work and support!
Whats your ZimaOS version?
Hi, to help investigate the CPU temperature readings, please connect to ZimaOS via SSH and run the following command. If prompted, enter your ZimaOS login password:
sudo curl -fL ‘https://zimaos-image.oss-us-west-1.aliyuncs.com/test/collect-cpu-temperature.sh?OSSAccessKeyId=LTAI5tNrA6heKFvGAPmmuSQu&Expires=1793255850&Signature=K53zwCmPczqG1e0e8sr0zWav%2Fwg%3D’ -o /tmp/collect-cpu-temperature.sh && sudo bash /tmp/collect-cpu-temperature.sh
The script collects three sets of diagnostic readings and usually takes about a minute. Please keep the NAS as idle as possible during collection. It does not change temperature thresholds or fan settings.
When finished, the terminal will display the report’s full path. By default, it is saved in /DATA with a filename like zimaos-cpu-temperature-…txt.
Please email the generated .txt file as an attachment to lvzhiyuan@icewhale.org, along with the CPU temperature shown in the web interface during collection, or a screenshot. Please use this email subject:
DXP4800 Plus CPU Temperature Diagnostic Report
Thank you for your help!
