Minor problem, Contents of Bin under storage settings is shown as Tb when it should be Gb.
Please take a screenshot.
My Bin contained 1.6GB shown in the Storage applet. I deleted a folder containing 75GB, Bin contents now shows some random quantity in TB.
Also, in the Files applet, It’s called Trash, in the storage applet it’s called Bin. Both should use the same name in my opinion.
Now I discover that each of the thousands of files that I deleted to illustrate this problem for you, I have to put each file back individually. Your Trash or Bin management system needs some serious work and requires a proper hierarchical file management system to assist recovering accidentally deleted files and folders, or in this case, purposely deleted files. Not happy.
