Btop does not work in 1.5.1 on HP microserver g7 AMD N40L CPU
Hi
btop does not start/work on zimaos 1.5.1. Just gives a black screen.
Did rollback to 1.5.0 and there it works fine.
This is the specs of the system. https://n40l.fandom.com/wiki/Base_Hardware_N40L
Thanks
Jesper
Also a problem on 1.5.2 beta 2
I also tried btop via ssh as sudo, same thing, black screen and have to exit with ctrl + c.
We recently upgraded to the version of Btop, and perhaps this is causing the problem.
