Hello,
I posted something similar in the wrong spot earlier today. I installed 1.4.2 beta 2 and firstly the system seems very responsive so great job on that front. I did run into what appears to be a internet access problem in the area of I can’t download new apps or update the apps already installed. The process starts and just hangs there, it’s been like this for 2 days now.
Thanks for your feedback. To better help you:
What country are you in? ISP used? Using a wired connection to Ethernet or Wi-Fi? Is there a VPN or other network firewall? Are there other administrators to manage the network?
Did you change your network or notice any changes before or after installing beta 2?
Always attach the specs of your hardware. Photos of your device would be helpful. Videos are better. These are all for locating the issue.
Sorry dubbled posted when I found the area just for the beta. Please disregard this post.
