I just found that Time Machine backup was not working. Looking a bit more, avahi daemon crashed and can’t restart. Restarting smb doesn’t help.
Complete reboot with option for TimeMachine unchecked bring back avahi.
Is it a known bug?
Is it a known bug?
After doing some tests with beta 5 with offline install
, I was able to set up again the Time Machine share, reboot and successfully do the backup.
But I found the trigger that crash avahi, logging to the Zima webinterface. A the same second the Bonjour record disappear from Discovery app and the Finder sidebar and only a reboot bring back avahi, but only until I log back in the web interface…
After a reboot, here the socket used:
sudo lsof /var/run/avahi-daemon/socket 2>/dev/null | grep avahi
1372 /sbin/avahi-dnsconfd 0 /dev/null
1372 /sbin/avahi-dnsconfd 1 socket:[9626]
1372 /sbin/avahi-dnsconfd 2 socket:[9626]
1372 /sbin/avahi-dnsconfd 3 pipe:[10726]
1372 /sbin/avahi-dnsconfd 4 pipe:[10726]
1372 /sbin/avahi-dnsconfd 5 socket:[10727]
1372 /sbin/avahi-dnsconfd 6 socket:[9651]
1374 /sbin/avahi-daemon 0 /dev/null
1374 /sbin/avahi-daemon 1 socket:[9627]
1374 /sbin/avahi-daemon 2 socket:[9627]
1374 /sbin/avahi-daemon 3 socket:[5964]
1374 /sbin/avahi-daemon 4 socket:[11603]
1374 /sbin/avahi-daemon 5 socket:[11605]
1374 /sbin/avahi-daemon 6 pipe:[11608]
1374 /sbin/avahi-daemon 7 pipe:[11608]
1374 /sbin/avahi-daemon 8 pipe:[11609]
1374 /sbin/avahi-daemon 9 pipe:[11609]
1374 /sbin/avahi-daemon 10 socket:[11610]
1374 /sbin/avahi-daemon 11 anon_inode:inotify
1374 /sbin/avahi-daemon 12 socket:[9644]
1374 /sbin/avahi-daemon 13 socket:[9645]
1374 /sbin/avahi-daemon 14 socket:[9646]
1374 /sbin/avahi-daemon 15 socket:[9647]
1374 /sbin/avahi-daemon 16 socket:[9648]
1374 /sbin/avahi-daemon 17 socket:[9650]
1375 /sbin/avahi-daemon 0 /dev/null
1375 /sbin/avahi-daemon 1 socket:[9627]
1375 /sbin/avahi-daemon 2 socket:[9627]
1375 /sbin/avahi-daemon 3 socket:[5964]
1375 /sbin/avahi-daemon 4 socket:[11603]
1375 /sbin/avahi-daemon 6 socket:[11606]
12717 /package/admin/s6-2.13.1.0/command/s6-supervise 3 /run/s6-rc:s6-rc-init:Bffjom/servicedirs/avahi/supervise/lock
12717 /package/admin/s6-2.13.1.0/command/s6-supervise 4 /run/s6-rc:s6-rc-init:Bffjom/servicedirs/avahi/supervise/control
12717 /package/admin/s6-2.13.1.0/command/s6-supervise 5 /run/s6-rc:s6-rc-init:Bffjom/servicedirs/avahi/supervise/control
13977 /usr/sbin/avahi-daemon 0 /dev/null
13977 /usr/sbin/avahi-daemon 1 pipe:[76225]
13977 /usr/sbin/avahi-daemon 2 pipe:[76226]
13977 /usr/sbin/avahi-daemon 3 pipe:[83973]
13977 /usr/sbin/avahi-daemon 4 pipe:[83973]
13977 /usr/sbin/avahi-daemon 5 pipe:[83974]
13977 /usr/sbin/avahi-daemon 6 pipe:[83974]
13977 /usr/sbin/avahi-daemon 7 socket:[83975]
13977 /usr/sbin/avahi-daemon 8 socket:[83976]
13977 /usr/sbin/avahi-daemon 9 anon_inode:inotify
13977 /usr/sbin/avahi-daemon 10 socket:[83979]
13977 /usr/sbin/avahi-daemon 11 socket:[83980]
13977 /usr/sbin/avahi-daemon 12 socket:[83981]
After connecting to the web interface, PID 1372 to 1375 disappear and status of avahi-daemon show failed restart requests:
× avahi-daemon.service - Avahi mDNS/DNS-SD Stack
Loaded: loaded (/usr/lib/systemd/system/avahi-daemon.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sat 2026-04-11 23:02:59 CEST; 20h ago
Duration: 6min 43.910s
Invocation: 9587aed161d94ff19eba627f84ad7ac0
TriggeredBy: × avahi-daemon.socket
Process: 27691 ExecStart=/usr/sbin/avahi-daemon -s (code=exited, status=255/EXCEPTION)
Main PID: 27691 (code=exited, status=255/EXCEPTION)
Apr 11 23:02:59 ZimaOS avahi-daemon[27691]: Found user ‘avahi’ (UID 100) and group ‘avahi’ (GID 101).
Apr 11 23:02:59 ZimaOS avahi-daemon[27691]: Successfully dropped root privileges.
Apr 11 23:02:59 ZimaOS avahi-daemon[27691]: chroot.c: fork() failed: Resource temporarily unavailable
Apr 11 23:02:59 ZimaOS avahi-daemon[27691]: failed to start chroot() helper daemon.
Apr 11 23:02:59 ZimaOS systemd[1]: avahi-daemon.service: Main process exited, code=exited, status=255/EXCEPTION
Apr 11 23:02:59 ZimaOS systemd[1]: :5:185m:5:185mavahi-daemon.service: Failed with result ‘exit-code’.
Apr 11 23:02:59 ZimaOS systemd[1]: Failed to start Avahi mDNS/DNS-SD Stack.
Apr 11 23:02:59 ZimaOS systemd[1]: :5:185m:5:185mavahi-daemon.service: Start request repeated too quickly.
Connecting to Zima app on iOS gave the same crash result as the web interface connection!
Any help? I downloaded Beta 6 but the offline update process doesn’t pick it up, so I can test it.
It was possible to start avahi again but only with no-chroot parameter:
sudo /usr/sbin/avahi-daemon -D --no-chroot
