Hi guys,
I updated ZimaOS to 1.24-beta2 - The first impression after great improvements that Assist missed from the list of installed applications. After that 1.24 … and a few days ago, 1.25-beta2. The Assistant is still missing. I see that folder Assist exists on the system partition.
How can I recover it to be available on the application list?
It will be good what is architecture of IceWhale AI solution on ZimaCube Pro? I started using ZCP for local AI with access to the local repository. I would like to spend some time extending functionality and optimizing it from many perspectives…
Is there anybody who actively used it on ZCP? Any plans?
Regards
- We’ve removed Assist after careful consideration because we’ve found an even better AI big model that is Open Web UI and would love for you to apply it and give some feedback please
It supports the latest language models, including but not limited to Llama3 and Gemma, and is compatible with OpenAI’s API. Additionally, Open WebUI will call on the ZimaCube Pro Creator’s built-in NVIDIA 2000 Ada GPU to reduce processing latency
Most importantly, all your data (including login details) is locally stored on your device. Open WebUI ensures strict confidentiality under your authorization, with no external requests, protecting your privacy and enhancing your security
