ASRock Thunderbolt 3 AIC R2.0
I have chosen to build a NAS on ASROCK H470m as it supports a thunderbolt 3 card with intel JHL6540 controller. The ZimaOS loaded 512gb nvme drive (older drives wouldn’t install the image), 10 port 1166 card with 8x 4TB drives. The usb devices don’t show up in the network tab, are connected in the drive plane, usb will connect through the thunderbolt card and add 10TB G-drive to stoage. The thunderbolt 10tb drive did connect and retaining the data on the backup drive, only stayed for a few minutes and wouldn’t recognize it again.
I would like to see through put of the usb on the network graphs or its own widget
Hi, ZimaOS is built for Zima devices. It is open to third-party devices but might have compatibility issues. For now, the ZimaCube Pro has a built-in Thunderbolt 4 controller, and your version is Thunderbolt 3. I think this might be the cause.
