Having issue when opening apps by clicking but open fine if i manually type the ip.
already restarted docker and app manager via the terminal and of course did power cycle by unplugging pc completely.
This usually happens when the ZimaOS app launcher loads before Docker and ends up using an outdated route. That’s why typing the IP works, but clicking the app doesn’t.
Nothing in your containers is broken. The launcher just needs a fresh scan of the running apps.
A normal reboot forces the backend to rebuild the app map, and the links start working again. Since you already restarted Docker manually, rebooting the system is the simplest fix.
Thanks for the reply. Had same issue after reboot but after about a day or so it just started working as expected again.
