Apps fail to load
Hello like the title says apps take a long time to load and they fail to load. This has been a common problem for me since 1.4.1 upgrade.
I’m self hosting approximately 10 apps (I can’t give you a exact number because they will not load) the systems memory and CPU are not being taxed.
It appears that this wasn’t such a problem when fewer apps (4 to 6) where installed.
Hardware has not changed in 3 zimaos version upgrades.
Older i7
16 gb ram
Zimaos 1.4.1
Any help would be appreciated
Thank you
Just was able to get into this and something for the os is taxing my system hard.
Try to turn off search index in the developer settings.
Thank you for your feedback. We have mainly optimized the above issues you mentioned in ZimaOS 1.4.2:
  1. Rapid improvement in application loading speed.
  2. Optimize the update logic of the application
  3. Improve the speed of downloading applications
If everything goes well, we will release the beta version of 1.4.2 this week. If you want to try it , please leave me a message.
Hey thanks for the reply, I did turn that off and it made a massive improvement in system responses (see photo) after the apps have loaded but it still takes the web page a good 2 plus minutes to load the apps if I keep refreshing the browser.
Hey Spider, thanks for being on top of this. Turning off surch indexing made enough of a improvement that it allows me to use my services again and that will work until the next public release. Thank you for the opportunity thoug
Glad to hear you’ve solved it. We expect to open beta testing this week, you can turn on this switch in settings, and you will receive update notifications by then. If you encounter any problems, please feel free to contact me.
