Greetings All,
I am brand new to ZimaOS. I have been using Synology since 2011, and they are just not powerful enough any longer. So, I am diving into ZimaOS with both feet, rather than Proxmox/TrueNAS/OMV, etc., because it should be simpler (although I will surely make it complicated, shortly). Primary goal is to replace my Plex and ARR stack on Synology. And, then Home Assistant and beyond.
I have the following disk layout:
ZimaOS-HD System (256GB NVMe) 212 GB Available / 238 GB
Main-SSD (3x 1TB SSD’s) RAID5 2.05 TB Available / 2.05 TB
Data-RustX3 (8x 3TB HD’s) RAID5 20.2 TB Available / 21 TB
Data-RustX6 (4x 6TB HD’s) RAID5 18 TB Available / 18 TB
Data-RustX2 (4x 2TB HD’s) RAID5 6 TB Available / 6 TB
My intent was to used the Data-Rust storage for Movies, TV, Music, and whatever. And, the SSD’s for the containers and such.
Should I move “App data”, “App image”, and “User database” to the Main-SSD, or is the 256GB ZimaOS-HD large enough to handle this data? If/when I deploy any VM’s, I would certainly put the boot disks in Main-SSD.
What are the Best Practices for backing up ZimaOS-HD?
Thanks, Doug
