A user contacted me on Discord to discuss an idea to have flexibility in where to mount the PCIe card for the ZimaBoard. As we all know the small footprint of the ZimaBoard is a great feature.
After discussing a few ideas i got to work and after a few prototypes came up with the final design.
This printable bracket allows you to mount the M.2 PCIe board to the base of your ZimaBoard and using a short PCIe Riser cable you can keep the small footprint present.
The link for the board can be found below:
