About backups for the Zima OS system and its apps
To secure my installation,
a colleague just suggested I make a backup.
I’m open to it, but right now, my system drive is 2TB,
and the M.2 SATA SSD I have is about 447GB.
So I’m wondering if it’s possible to back up the system and, if so, how?
I’m thinking of backing up the system, the app settings, and the apps themselves—but without the data.
But I don’t know if that’s possible or how to do it.
If you could give me some information or help me out…
that would be great.
Best regards.
Thank you.
Dany.
Translated with DeepL.com (free version)
The simplest and cheapest option to begin with is using an external drive to save your most valuable files on a regular basis : meaning your data (files, photos…). This can be done manually or you can set up a cron job to do it for you, and you can also add the various apps settings yoiu’re using to this basic schedule : to be honest, backing up the entire system doesn’t really matter as it can always be reset or reinstalled on a new machine… But you will never ever be able to reshoot your holiday photos from last summer in Xalapa !!!
Next step could be to set yourself up a NAS to automate your backups : it’s not complicated and there are plenty of examples available on the interweb. Note that the Zimablade NAS kit is perfect for this kind of task (and Im’ not working for them :slight_smile:).
Add to this second (encrypted) backup, using a cloud account (free or paid depending on your storage needs) : Google Drive, OneDrive, Dropbox, Mega… Just choose your weapon :laughing:
After that you can consider relatively safe :slight_smile:
I found this:
It seems that Zima greatly simplifies the backup process.
I’m not sure if I’m right or if I’m mistaken.
Do you recommend this method or another one?
For example, Clonezilla (or something else like a live CD)
from a USB drive?
Best regards.
Respectfully,
Dany.
Can’t say what’s precisely being backed up (everything ?!) but here it says your backup size is 131 Go, so you can start with a backup onto an external hard drive and another onto a cloud account : free plans won’t be enough but pCloud or Internxt, to name a few, offer lifetime plans that are interesting.
Thanks, @jme69 .
I looked at your suggestions.
PCloud seems interesting at first glance.
Internxt is way too expensive.
€1,900 for 1 TB of storage is prohibitive.
That leaves Google Drive, which I’m used to using, but I don’t know their pricing.
Thanks anyway.
I think I’ll go with a USB drive.
Even if it’s expensive (what isn’t these days?),
it’ll still be much cheaper than those cloud solutions.
Internxt is only 247€ if you claim the offer, which is a really good deal for a lifetime plan :zany_face:
No idea about Google, I’m staying away from it as much as possible :joy:
Yes, I can prove you’re not one of our employees, hahaha.
If you want to take control…with rsync…this is also an option: Taming ZimaOS – Building a reboot-proof scheduled backup system for my NAS
Hello, everyone.
I’m wondering about this.
Regarding my backups.
Does the free version of Zima OS allow me to create an additional pool?
I’ll call it “backup” or “storage,”
and I’ll copy my NAS into it specifically for backup purposes.
Or is it better to use an external USB drive?
Best regards,
Dany.
