A Comprehensive Guide to Installing AzuraCast on ZimaOS
AzuraCast is a self‑hosted, all‑in‑one web radio management suite. With it, you can run multiple online radio stations, manage playlists, configure AutoDJ, and explore many other creative broadcasting options. Although there are plenty of articles and YouTube tutorials explaining how to set up AzuraCast on various platforms, I found no complete step‑by‑step guide specifically for ZimaOS. This article aims to fill that gap.
After considerable trial and error—using AzuraCast’s documentation, GitHub resources, SSH installs, and even Portainer tweaks—I finally arrived at a simple, reliable configuration that works perfectly on ZimaOS. This guide will walk you through that process.
Note: This tutorial focuses on installing AzuraCast for home or private use, accessible within your local network or via Tailscale. If you plan to expose your AzuraCast instance to the public internet, you may need to adjust certain network and security settings.
Hardware and System Used
This installation was performed on a ZimaBoard with the following specifications:
  • CPU: Intel Celeron N3450 @ 1.10 GHz (4 cores, 4 threads)
  • RAM: 8 GB LPDDR4 @ 1600 MHz
  • GPU: Intel HD Graphics 500
  • Operating System: ZimaOS v1.5.3 Plus
Let’s get AzuraCast installed!
Preparing the Custom Docker Compose File
I created a modified Docker Compose file tailored for ZimaOS. Once you load it through the Custom App interface, a few adjustments are required before installation. Follow the steps below:
Step‑by‑Step Installation Guide
1. Log in to ZimaOS Open your ZimaOS dashboard and click the + icon in the top‑right corner.
Select Install a customized app.
2. Import the Docker Compose file A pop‑up window will appear. Click Import in the top‑right corner.
Paste the modified Docker Compose YAML into the Docker Compose tab, then click Submit.
services:
  updater:
    cpu_shares: 90
    command: []
    container_name: azuracast_updater
    deploy:
      resources:
        limits:
          memory: 8169115648
        reservations:
          devices: []
    image: ghcr.io/azuracast/updater:latest
    labels:
      icon: https://www.azuracast.com/_astro/logo.VgI79CYu.svg
    logging:
      options:
        max-file: "5"
        max-size: 1m
    restart: unless-stopped
    volumes:
      - type: bind
        source: /var/run/docker.sock
        target: /var/run/docker.sock
        bind:
          create_host_path: true
    ports: []
    devices: []
    cap_add: []
    environment: []
    network_mode: bridge
    privileged: false
  web:
    cpu_shares: 90
    command: []
    deploy:
      resources:
        limits:
          memory: 8169115648
        reservations:
          devices: []
    environment:
      - APPLICATION_ENV=production
      - AUTO_ASSIGN_PORT_MAX=8499
      - AUTO_ASSIGN_PORT_MIN=8000
      - AZURACAST_VERSION=latest
      - COMPOSE_HTTP_TIMEOUT=300
      - COMPOSE_PROJECT_NAME=azuracast
      - COMPOSER_PLUGIN_MODE=false
      - ENABLE_WEB_UPDATER=true
      - LANG=en_US
      - MYSQL_DATABASE=azuracast
      - MYSQL_HOST=localhost
      - MYSQL_PASSWORD=jTzH2ZxQajHF
      - MYSQL_PORT=3306
      - MYSQL_ROOT_PASSWORD=pqnkyDPTHwfNxDWKkPWR
      - MYSQL_USER=azuracast
      - NGINX_BLOCK_BOTS=false
      - NGINX_TIMEOUT=1800
      - REDIS_HOST=localhost
      - REDIS_PORT=6379
      - SHOW_DETAILED_ERRORS=false
    image: ghcr.io/azuracast/azuracast:latest
    labels:
      com.centurylinklabs.watchtower.scope: azuracast
    logging:
      options:
        max-file: "5"
        max-size: 1m
    ports:
      - mode: ingress
        target: 80
        published: "82"
        protocol: tcp
      - mode: ingress
        target: 443
        published: "446"
        protocol: tcp
      - mode: ingress
        target: 2022
        published: "2022"
        protocol: tcp
      - mode: ingress
        target: 8000
        published: "8499"
        protocol: tcp
      - mode: ingress
        target: 8005
        published: "8005"
        protocol: tcp
      - mode: ingress
        target: 8006
        published: "8006"
        protocol: tcp
      - mode: ingress
        target: 8010
        published: "8010"
        protocol: tcp
      - mode: ingress
        target: 8015
        published: "8015"
        protocol: tcp
      - mode: ingress
        target: 8016
        published: "8016"
        protocol: tcp
      - mode: ingress
        target: 8020
        published: "8020"
        protocol: tcp
      - mode: ingress
        target: 8025
        published: "8025"
        protocol: tcp
      - mode: ingress
        target: 8026
        published: "8026"
        protocol: tcp
      - mode: ingress
        target: 8030
        published: "8030"
        protocol: tcp
      - mode: ingress
        target: 8035
        published: "8035"
        protocol: tcp
      - mode: ingress
        target: 8036
        published: "8036"
        protocol: tcp
      - mode: ingress
        target: 8040
        published: "8040"
        protocol: tcp
      - mode: ingress
        target: 8045
        published: "8045"
        protocol: tcp
      - mode: ingress
        target: 8046
        published: "8046"
        protocol: tcp
      - mode: ingress
        target: 8050
        published: "8050"
        protocol: tcp
      - mode: ingress
        target: 8055
        published: "8055"
        protocol: tcp
      - mode: ingress
        target: 8056
        published: "8056"
        protocol: tcp
      - mode: ingress
        target: 8060
        published: "8060"
        protocol: tcp
      - mode: ingress
        target: 8065
        published: "8065"
        protocol: tcp
      - mode: ingress
        target: 8066
        published: "8066"
        protocol: tcp
      - mode: ingress
        target: 8070
        published: "8070"
        protocol: tcp
      - mode: ingress
        target: 8075
        published: "8075"
        protocol: tcp
      - mode: ingress
        target: 8076
        published: "8076"
        protocol: tcp
      - mode: ingress
        target: 8090
        published: "8090"
        protocol: tcp
      - mode: ingress
        target: 8095
        published: "8095"
        protocol: tcp
      - mode: ingress
        target: 8096
        published: "8096"
        protocol: tcp
      - mode: ingress
        target: 8100
        published: "8100"
        protocol: tcp
      - mode: ingress
        target: 8105
        published: "8105"
        protocol: tcp
      - mode: ingress
        target: 8106
        published: "8106"
        protocol: tcp
      - mode: ingress
        target: 8110
        published: "8110"
        protocol: tcp
      - mode: ingress
        target: 8115
        published: "8115"
        protocol: tcp
      - mode: ingress
        target: 8116
        published: "8116"
        protocol: tcp
      - mode: ingress
        target: 8120
        published: "8120"
        protocol: tcp
      - mode: ingress
        target: 8125
        published: "8125"
        protocol: tcp
      - mode: ingress
        target: 8126
        published: "8126"
        protocol: tcp
      - mode: ingress
        target: 8130
        published: "8130"
        protocol: tcp
      - mode: ingress
        target: 8135
        published: "8135"
        protocol: tcp
      - mode: ingress
        target: 8136
        published: "8136"
        protocol: tcp
      - mode: ingress
        target: 8140
        published: "8140"
        protocol: tcp
      - mode: ingress
        target: 8145
        published: "8145"
        protocol: tcp
      - mode: ingress
        target: 8146
        published: "8146"
        protocol: tcp
      - mode: ingress
        target: 8150
        published: "8150"
        protocol: tcp
      - mode: ingress
        target: 8155
        published: "8155"
        protocol: tcp
      - mode: ingress
        target: 8156
        published: "8156"
        protocol: tcp
      - mode: ingress
        target: 8160
        published: "8160"
        protocol: tcp
      - mode: ingress
        target: 8165
        published: "8165"
        protocol: tcp
      - mode: ingress
        target: 8166
        published: "8166"
        protocol: tcp
      - mode: ingress
        target: 8170
        published: "8170"
        protocol: tcp
      - mode: ingress
        target: 8175
        published: "8175"
        protocol: tcp
      - mode: ingress
        target: 8176
        published: "8176"
        protocol: tcp
      - mode: ingress
        target: 8180
        published: "8180"
        protocol: tcp
      - mode: ingress
        target: 8185
        published: "8185"
        protocol: tcp
      - mode: ingress
        target: 8186
        published: "8186"
        protocol: tcp
      - mode: ingress
        target: 8190
        published: "8190"
        protocol: tcp
      - mode: ingress
        target: 8195
        published: "8195"
        protocol: tcp
      - mode: ingress
        target: 8196
        published: "8196"
        protocol: tcp
      - mode: ingress
        target: 8200
        published: "8200"
        protocol: tcp
      - mode: ingress
        target: 8205
        published: "8205"
        protocol: tcp
      - mode: ingress
        target: 8206
        published: "8206"
        protocol: tcp
      - mode: ingress
        target: 8210
        published: "8210"
        protocol: tcp
      - mode: ingress
        target: 8215
        published: "8215"
        protocol: tcp
      - mode: ingress
        target: 8216
        published: "8216"
        protocol: tcp
      - mode: ingress
        target: 8220
        published: "8220"
        protocol: tcp
      - mode: ingress
        target: 8225
        published: "8225"
        protocol: tcp
      - mode: ingress
        target: 8226
        published: "8226"
        protocol: tcp
      - mode: ingress
        target: 8230
        published: "8230"
        protocol: tcp
      - mode: ingress
        target: 8235
        published: "8235"
        protocol: tcp
      - mode: ingress
        target: 8236
        published: "8236"
        protocol: tcp
      - mode: ingress
        target: 8240
        published: "8240"
        protocol: tcp
      - mode: ingress
        target: 8245
        published: "8245"
        protocol: tcp
      - mode: ingress
        target: 8246
        published: "8246"
        protocol: tcp
      - mode: ingress
        target: 8250
        published: "8250"
        protocol: tcp
      - mode: ingress
        target: 8255
        published: "8255"
        protocol: tcp
      - mode: ingress
        target: 8256
        published: "8256"
        protocol: tcp
      - mode: ingress
        target: 8260
        published: "8260"
        protocol: tcp
      - mode: ingress
        target: 8265
        published: "8265"
        protocol: tcp
      - mode: ingress
        target: 8266
        published: "8266"
        protocol: tcp
      - mode: ingress
        target: 8270
        published: "8270"
        protocol: tcp
      - mode: ingress
        target: 8275
        published: "8275"
        protocol: tcp
      - mode: ingress
        target: 8276
        published: "8276"
        protocol: tcp
      - mode: ingress
        target: 8280
        published: "8280"
        protocol: tcp
      - mode: ingress
        target: 8285
        published: "8285"
        protocol: tcp
      - mode: ingress
        target: 8286
        published: "8286"
        protocol: tcp
      - mode: ingress
        target: 8290
        published: "8290"
        protocol: tcp
      - mode: ingress
        target: 8295
        published: "8295"
        protocol: tcp
      - mode: ingress
        target: 8296
        published: "8296"
        protocol: tcp
      - mode: ingress
        target: 8300
        published: "8300"
        protocol: tcp
      - mode: ingress
        target: 8305
        published: "8305"
        protocol: tcp
      - mode: ingress
        target: 8306
        published: "8306"
        protocol: tcp
      - mode: ingress
        target: 8310
        published: "8310"
        protocol: tcp
      - mode: ingress
        target: 8315
        published: "8315"
        protocol: tcp
      - mode: ingress
        target: 8316
        published: "8316"
        protocol: tcp
      - mode: ingress
        target: 8320
        published: "8320"
        protocol: tcp
      - mode: ingress
        target: 8325
        published: "8325"
        protocol: tcp
      - mode: ingress
        target: 8326
        published: "8326"
        protocol: tcp
      - mode: ingress
        target: 8330
        published: "8330"
        protocol: tcp
      - mode: ingress
        target: 8335
        published: "8335"
        protocol: tcp
      - mode: ingress
        target: 8336
        published: "8336"
        protocol: tcp
      - mode: ingress
        target: 8340
        published: "8340"
        protocol: tcp
      - mode: ingress
        target: 8345
        published: "8345"
        protocol: tcp
      - mode: ingress
        target: 8346
        published: "8346"
        protocol: tcp
      - mode: ingress
        target: 8350
        published: "8350"
        protocol: tcp
      - mode: ingress
        target: 8355
        published: "8355"
        protocol: tcp
      - mode: ingress
        target: 8356
        published: "8356"
        protocol: tcp
      - mode: ingress
        target: 8360
        published: "8360"
        protocol: tcp
      - mode: ingress
        target: 8365
        published: "8365"
        protocol: tcp
      - mode: ingress
        target: 8366
        published: "8366"
        protocol: tcp
      - mode: ingress
        target: 8370
        published: "8370"
        protocol: tcp
      - mode: ingress
        target: 8375
        published: "8375"
        protocol: tcp
      - mode: ingress
        target: 8376
        published: "8376"
        protocol: tcp
      - mode: ingress
        target: 8380
        published: "8380"
        protocol: tcp
      - mode: ingress
        target: 8385
        published: "8385"
        protocol: tcp
      - mode: ingress
        target: 8386
        published: "8386"
        protocol: tcp
      - mode: ingress
        target: 8390
        published: "8390"
        protocol: tcp
      - mode: ingress
        target: 8395
        published: "8395"
        protocol: tcp
      - mode: ingress
        target: 8396
        published: "8396"
        protocol: tcp
      - mode: ingress
        target: 8400
        published: "8400"
        protocol: tcp
      - mode: ingress
        target: 8405
        published: "8405"
        protocol: tcp
      - mode: ingress
        target: 8406
        published: "8406"
        protocol: tcp
      - mode: ingress
        target: 8410
        published: "8410"
        protocol: tcp
      - mode: ingress
        target: 8415
        published: "8415"
        protocol: tcp
      - mode: ingress
        target: 8416
        published: "8416"
        protocol: tcp
      - mode: ingress
        target: 8420
        published: "8420"
        protocol: tcp
      - mode: ingress
        target: 8425
        published: "8425"
        protocol: tcp
      - mode: ingress
        target: 8426
        published: "8426"
        protocol: tcp
      - mode: ingress
        target: 8430
        published: "8430"
        protocol: tcp
      - mode: ingress
        target: 8435
        published: "8435"
        protocol: tcp
      - mode: ingress
        target: 8436
        published: "8436"
        protocol: tcp
      - mode: ingress
        target: 8440
        published: "8440"
        protocol: tcp
      - mode: ingress
        target: 8445
        published: "8445"
        protocol: tcp
      - mode: ingress
        target: 8446
        published: "8446"
        protocol: tcp
      - mode: ingress
        target: 8450
        published: "8450"
        protocol: tcp
      - mode: ingress
        target: 8455
        published: "8455"
        protocol: tcp
      - mode: ingress
        target: 8456
        published: "8456"
        protocol: tcp
      - mode: ingress
        target: 8460
        published: "8460"
        protocol: tcp
      - mode: ingress
        target: 8465
        published: "8465"
        protocol: tcp
      - mode: ingress
        target: 8466
        published: "8466"
        protocol: tcp
      - mode: ingress
        target: 8470
        published: "8470"
        protocol: tcp
      - mode: ingress
        target: 8475
        published: "8475"
        protocol: tcp
      - mode: ingress
        target: 8476
        published: "8476"
        protocol: tcp
      - mode: ingress
        target: 8480
        published: "8480"
        protocol: tcp
      - mode: ingress
        target: 8485
        published: "8485"
        protocol: tcp
      - mode: ingress
        target: 8486
        published: "8486"
        protocol: tcp
      - mode: ingress
        target: 8490
        published: "8490"
        protocol: tcp
      - mode: ingress
        target: 8495
        published: "8495"
        protocol: tcp
      - mode: ingress
        target: 8496
        published: "8496"
        protocol: tcp
    ulimits:
      nofile:
        soft: 65536
        hard: 65536
    volumes:
      - type: bind
        source: /media/SSD1/AppData/azuracast/stations
        target: /var/azuracast/stations
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/backups
        target: /var/azuracast/backups
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/mysql
        target: /var/lib/mysql
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/uploads
        target: /var/azuracast/storage/uploads
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/shoutcast2
        target: /var/azuracast/storage/shoutcast2
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/stereo_tool
        target: /var/azuracast/storage/stereo_tool
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/rsas
        target: /var/azuracast/storage/rsas
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/geolite
        target: /var/azuracast/storage/geoip
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/sftpgo
        target: /var/azuracast/storage/sftpgo
        bind:
      - type: bind
        source: /media/SSD1/AppData/azuracast/acme
        target: /var/azuracast/storage/acme
        bind:
      - type: bind
        source: /media/SSD2/Music
        target: /Music
    devices: []
    cap_add: []
    privileged: false
x-casaos:
  author: self
  category: self
  hostname: ""
  index: /
  is_uncontrolled: false
  port_map: "82"
  scheme: http
  store_app_id: azuracast
  tips:
    custom: |-
      Un:
      Pw:
  title:
    custom: Azuracast
You may see a warning message—just click OK.
3. Configure the App Settings
After loading the Compose file, you’ll see two tabs:
  • web
  • updater
Make the following adjustments:
Under the “web” tab
Change the host-side ports (do not modify container ports):
  • 80
  • 443
  • 8000
Set them to the host ports you prefer.
Set Volume paths on the ZimaOS side
Do not change the paths on the AzuraCast (container) side.
Later, you may add additional volumes for music storage.
Do not modify any Environment Variables (unless you are confident what you are doing).
Under the “updater” tab
Set the Web UI port.
This must match the host-side port you assigned to port 80 under the “web” tab.
4. Install the App
Click Install.
When installation completes, access your AzuraCast dashboard by visiting:
http://<your_server_ip>:<Web_UI_port>
Create your admin account, configure your first station, and start broadcasting!
Final Thoughts
With this configuration, AzuraCast runs smoothly on ZimaOS and is easy to maintain. After setup, you can expand your library, add radio stations, integrate AutoDJ, and explore all the powerful tools AzuraCast provides.
Merry Christmas — and Happy Broadcasting!
Thanks for the detailed install/info, it’s always great when the community helps out others like this!
Hi Friends,
By further experimenting I found that this installation method is sometimes not working and unstable. Automatic web updating of azuracast also has some problems with this installation method. Soon I will be preparing another (more detailed) guideline on how to install Azuracast in ZimaOS via SSH terminal. Still doing some experiments with SSH installation to identify limitations within ZimaOS.
