ZVM Virtual machine shows no Display
Hi all,
Looking to see if anyone has had this issue when using ZVM and trying to boot up a VM.
Do you have HTTPS enabled ? If yes, then disable it. the SSH and ZVM consoles work only through HTTP in current version
Hi,
https is off
Yes same issue for me as never worked since install
