Zimaos v1.7.0 media disk unssuported after upgrade
Hi,
After upgrading to v1.7.0 my 10TB media storage shows unsupported. Can’t enable the disk, only format option. Which I cannot, I have loads movies, anime an tv series in there that I cannot afford to loose.heeeeeeeeelp
Hi, can you run the following command in the command line? Then go to Files and find the diskinfo.log file to send to dina@icewhale.org
curl -fsSL https://get.casaos.io/diskinfo.sh | sudo bash
