ZimaOS queries registry-1.docker.io every 30 seconds
Hi team, I want to report a problem.
I’ve never written a problem report for anything before, so I apologize if I left anything out or if the formatting is bad.
I will describe this problem as follows:
ZimaOS, specifically the systemd zimaos-app-manager service is sending a query to registry-1.docker.io every 30 seconds.
And I can reproduce the problem like this:
I just did a fresh install in a VM on proxmox and it started right away.
I realized it was happening because I have pihole running on my network and I could see the constant queries.
And I have tried these operations to fix it:
I looked here on the forums and on the github, but I couldn’t find anyone reporting this issue.
I used the ssh web terminal to poke around using my user account that was made when first starting the server. I temporarily disabled “zimaos-app-manager.service” and the problem stopped. Of course now I could no longer use the app store.
And here are the specs of my machine:
I honestly don’t know the exact specs. It’s an old pc I had lying around. It’s running proxmox. I installed ZimaOS in a VM using usb pass-through for the installer.
It’s ZimaOS 1.5
I have been using the web client for everything. I haven’t downloaded the app yet because this setup is temporary so I can check it out and decide if I want to use it for real.
My browser is Firefox in case that’s relevant.
I don’t know if this is related, but while looking through the logs found in /var/log/casaos/ I saw that the app-manager had some issues. I’ll paste them here:
2025-10-12T02:17:53.364Z        info    failed to parse compose app - contact the contributor of this app to fix it     {"error": "validating : services.redis.healthcheck.retries must be a number", "composeFile": "/var/lib/casaos/appstore/github.com/2a1238d53212bfce4e8f861dcb8ef3>
2025-10-12T02:17:53.962Z        info    failed to parse compose app - contact the contributor of this app to fix it     {"error": "validating : services.big-bear-pocketid.devices must be a list", "composeFile": "/var/lib/casaos/appstore/github.com/2a1238d53212bfce4e8f861dcb8ef3fe>
2025-10-12T02:17:54.178Z        info    featured apps file not found    {"featuredAppsFile": "/var/lib/casaos/appstore/github.com/2a1238d53212bfce4e8f861dcb8ef3fe/big-bear-casaos-master/featured-apps.json", "func": "service.LoadFeaturedApps", "file": "/home/runner/work/ZimaOS-App>
I’ve also attached a screenshot of my pihole query log. Here “test.home” is a local dns record that points to my VM running ZimaOS.
Thank you very much for your feedback! This is a docker hub accelerated configuration tuning strategy and timing detection, you are right, it should not be 30s loop ping, we will optimize this strategy in the next version (1.5.1)
i see this is already being resolved but wanted to confirm im having the same issues. its sending out 2 request every 30 seconds. doing 5644 request in a 24 hour period. ZimaOS v1.5.0 on a zimaboard 832. screenshot of adguard home log
We have released version 1.5.1 beta. If it is convenient, please update to the new version and check if the problem has been resolved. We look forward to your reply.
