Hello ZimaOS Team,
Thank you for considering my suggestions and sharing them with your team. I would like to explain my concerns more clearly, based on my personal experience using ZimaOS and its Photos application.
My goal is to help make ZimaOS a more stable, efficient, and user-friendly alternative to heavier self-hosted applications like Immich, especially for users running home servers with limited hardware resources.
My Suggestions and Concerns
1. CPU Power Management in ZimaOS Settings
Please add a dedicated CPU power management option in ZimaOS settings, with modes such as:
Power Saving
Balanced / Adaptive
High Performance
Maximum Performance
This would allow users to choose between lower power consumption, reduced temperatures, and maximum processing speed according to their needs.
2. HDD Power Management and APM Settings
Please provide proper hard drive power management controls, including:
Enable or disable HDD spin-down.
Configure the spin-down timer.
Adjust Advanced Power Management (APM), where supported by the drive.
Choose between power-saving and performance-oriented settings.
These options would help users manage HDD temperatures, power consumption, and unnecessary drive activity, potentially improving drive longevity when configured appropriately.
3. Swap / Virtual Memory Management
Please add a simple option in ZimaOS settings to enable or disable swap and configure its usage.
For example, my server has 12 GB of RAM, and I would like the flexibility to run without swap for my particular workload. Currently, manually changing the swap configuration does not persist after reboot, as ZimaOS appears to restore its default configuration.
A supported setting in the official UI would be much safer and more convenient than manually modifying system files. Ideally, users should also be able to configure swap size or usage limits.
4. CPU Utilization Controls in the Photos Application
Please add processing modes or a CPU usage limit for background photo processing in the Photos application.
For example:
Low Resource Usage
Balanced
Maximum Performance
During my testing, the ZimaOS Photos AI worker appeared to use only around 12% of CPU capacity at times, even while processing a large photo library. I have approximately 26,000 photos, and processing around 6,000 took five days of continuous operation.
A configurable resource limit would allow users to dedicate more CPU capacity to photo processing when faster completion is a priority, while retaining the option to keep the server responsive for other services.
5. GPU and iGPU Power Management
Please consider adding GPU power management options similar to CPU power modes, where supported by the hardware:
Power Saving
Balanced
High Performance
It would also be helpful to have a centralized GPU management system that allows applications to share available GPU resources efficiently.
This could improve AI processing performance and make better use of the available integrated GPU (iGPU) or dedicated GPU (dGPU).
6. Unnecessary HDD Spinning Despite Configured Spin-Down
I have three HDDs in my server. Two drives are configured in RAID 1 and are used for photo data and processing, while the third drive is used infrequently.
Despite configuring a 20-minute spin-down setting in ZimaOS, I noticed that the third HDD continues spinning even when I am not actively using it.
This behaviour started becoming noticeable after I began using the Photos application. Could the team investigate whether background services, disk monitoring, indexing, RAID activity, or other system processes are preventing unused drives from entering standby?
Ideally, ZimaOS should help users identify which processes are accessing a drive and allow compatible, unused drives to spin down safely without affecting RAID integrity or system stability.
7. Better iGPU Memory Allocation, Monitoring, and Utilization
My server uses an integrated GPU, and I have configured the BIOS to allocate shared system RAM to it automatically. However, the expected memory allocation and GPU utilization do not appear to work as intended in ZimaOS.
It would be helpful to have:
Accurate iGPU and dGPU detection.
GPU utilization, temperature, memory usage, and processing statistics.
Better visibility into shared GPU memory allocation.
Improved support for BIOS-configured shared memory.
Clear information about which applications are using GPU acceleration.
This would help users verify whether their hardware is being utilized correctly and identify potential bottlenecks during AI and photo processing.
Final Thoughts
I understand that implementing these features requires considerable development, hardware compatibility testing, and stability checks across different server configurations. I appreciate the team’s efforts to maintain ZimaOS as a reliable and accessible platform.
These suggestions are based on my actual experience and testing. I believe that providing users with more control over CPU power, GPU resources, memory, and hard drive behaviour would make ZimaOS even more useful for home servers.
Thank you again for your time, for listening to community feedback, and for continuously improving ZimaOS and its Photos application.
I will continue sharing my observations and suggestions as I use the system.
Best regards,
TheWall
