ZIMAOS con AMD cpu
I installed zimaos on a PC with an AMD processor but apparently ziamos reads the AMD kernel sensors incorrectly and I find the temperature of one of my 2 nvme as the CPU temperature. It’s not good. These are mine hwmon:
=== /sys/class/hwmon/hwmon0 ===
nvme
Composite
temp1_input: 52850
=== /sys/class/hwmon/hwmon1 ===
nvme
Composite
Sensor 1
Sensor 2
temp1_input: 49850
temp2_input: 49850
temp3_input: 47850
=== /sys/class/hwmon/hwmon2 ===
k10temp
Tctl
temp1_input: 47125
=== /sys/class/hwmon/hwmon3 ===
amdgpu
edge
temp1_input: 43000
there is a possibility to fix it and to be precise it is :
AMD Ryzen 5 PRO 4650GE with Radeon Graphics
6 Cores3.30 GHz12 Threads
I didn’t think AMD would be abandoned
