ZimaOS Backup not working
I cannot choose the local disks/folders in the ZimaOS only external sources. When I choose the ZimaOS Storage I only get a white line.
What version of Zima OS are you using? 1.5.1 should fix that problem.
I have version 1.5.1 and still get the white line when i choose ZimaOS Storage.
Are you booting ZimaOS from USB or Proxmox?
From usb
Have tried the same and had the same bug. ZimaOS is not build to run from USB. Have you tried running ZimaOS on internal drive?
