🚀 ZimaNet Beta testers wanted! We need U!
Hi @everyoneeveryone,
We’ve been rebuilding the remote access experience in Zima Client and we want you to try it. Now we can connect in as little as 3S, switch between remote devices in under 1S even when they’re 1,000 km apart. This Beta focuses on faster connections, better stability, smoother multi-device switching, and more flexible ways to connect.
What’s new in this Beta:
  • Faster, more stable connections: Automatically selects low-latency nodes and retries when the network is unstable
  • More ways to connect: Local network discovery, Network ID, and direct IP connections, including IPs assigned by Tailscale or ZeroTier
  • Smoother experience: Remember passwords, view real-time traffic on desktop, and upload feedback reports with one click
  • Better multi-device support: Switch between devices more smoothly, with connections automatically restored when the new link is ready
Other improvements
  • More reliable backups: Improved session management and file uploads, so switching devices won’t interrupt ongoing backups
  • More reliable SMB mounting: Fixed Windows credential conflicts and macOS Finder mounting issues
This Beta is available on iOS, Android, Windows, and macOS.
We’d especially like your help testing:
  1. Connection success
  2. Connection speed
  3. Connection stability
  4. Overall experience
Download Link:
Test Guide:
ZimaNet Remote Access Testing Guide (3).pdf (4.1 MB)
On mobile, ZimaNet can now switch between remote devices in under 3 seconds — even when the devices are 1,000+ km apart.
After testing, please remember to submit your feedback report. Your feedback directly helps us improve ZimaNet.
If you have any questions or feedback, feel free let us know. Thanks for helping us build a better ZimaNet! :high_voltage:
Best,
ZimaOS Team
Hello! thanks for the update! I updated my iOS and Mac app. I’m currently away from home and can only reach Zima with the ZeroTier local IP, zimaos.local no longer works on my Mac (macOS 27). Was running the macOS beta before with no issues.
Got it, we will fix ASAP.
