ZimaClient remote access repeatedly connects/disconnects
I am testing ZimaOS as a home server and have been evaluating whether it is suitable for multiple users to remotely access, save, and back up files.
Local access works normally. When a phone is connected to the same LAN as the server, ZimaClient works and I can access the ZimaOS dashboard and play videos without problems.
The problem occurs with remote access from outside the LAN.
I tested the Android ZimaClient from both:
  • Another Wi-Fi network
  • Cellular data
The behavior is intermittent. Sometimes the client connects and displays the server, but monitoring disappears or the connection drops. Video access is also inconsistent: one video may play while another fails.
The server itself is connected normally to the Internet. I also tested the server locally and the same videos that failed remotely played normally locally.
ZimaNet/EasyTier logs
The ZimaNet service is running continuously and the control plane appears healthy:
INFO zimanet::control_plane:
control-plane peer URLs synchronized
network_name=“983bxxxxxx”
revision=31 peer_count=6
However, when the Android client attempts to connect remotely, the server repeatedly reports the Android device joining and leaving the EasyTier network.
For example:
Oct 06 18:26:17 … other device joined EasyTier network
device_hostname=“Zima-Android-8c4d70xxxxxx”
device_virtual_ipv4=“10.xxx.xxx.2”
Oct 06 18:26:23 … other device left EasyTier network
device_hostname=“Zima-Android-8c4d70xxxxxxx”
device_virtual_ipv4="10.xxx
xxx.2"
Oct 06 18:26:29 … other device joined EasyTier network
device_hostname=“Zima-Android-8c4d70-xxxxxx”
Oct 06 18:26:32 … other device left EasyTier network
There were several other occurrences:
17:48:02 joined
17:48:14 left
17:48:17 joined
17:48:23 left
17:59:29 joined
18:01:02 left
18:19:17 joined
18:19:23 left
18:19:26 joined
18:21:11 left
18:21:29 joined
18:21:50 left
The ZimaNet service itself does not report corresponding errors, warnings, NAT failures, STUN failures, relay failures, or timeouts in the journal.
The ZimaCube’s EasyTier interface is present:
tun0: <POINTOPOINT,UP,LOWER_UP>
inet 10.xxx.xx/.1/24
The Android client receives the virtual address “10.xxx.xxx.2”.
Question
Does this join/leave behavior indicate a known ZimaNet/EasyTier or Android ZimaClient problem?
Is there a newer ZimaClient/ZimaNet version or configuration that addresses this?
Remote access is important for my intended use because other users need to be able to save and back up files to the server. At the moment I don’t consider the remote connection reliable enough for that purpose.
Thanks for the detailed report and for sharing the logs. This was very helpful.
We’ve identified and fixed the issue related to the repeated connect/disconnect behavior. We’ll provide you with the latest ZimaClient installation package shortly so you can test it again.
Also, for security reasons, could you please remove your Remote ID from the post? It’s better not to share this information publicly.
Thanks again for helping us track this down and for taking the time to test ZimaClient.
Please try the new version, look forward your test!
Thanks for your prompt response. In an abundance of safety, I checked the signing of the file sent and it differs from the signing in the “official” version. Can you confirm who is signing the file you posted and what is the SHA-256?
Thank you very much for your caution. I am from the ZimaOS development team, or we are about to release the official version Zima Client iOS/ Android v1.7.1. You can wait until tomorrow to download the official update package.
I tried the recently released version and the problem was solved. Thanks
I tested the update again from my android using an external network and wireless, and it did not work. I am thinking now that my previous test made was unadvertedly done when connected to my network. Really disappointed. I will try to provide some specifics but wanted first to recant my previous comment.
Alternatively, you can provide a screen recording.
I realized that the issue was in the router, so should no have blamed Zimaos! It is working fine now.
