Hi,
I received my Zimaboard 2 and started testing it. At first start it worked fine. When I restart the server apps does not load. And still on ZimaOS v1.4.3. (This is a known issue for ZimaOS v1.4.3 with docker services not starting) My device still not received latest zimaos updates. I kept server on for nearly 6 hours now and is connected to internet continuously. Is there a way to force update to V 15.1? Kind guidance is really appreciated.
Since you’re already aware that v1.4.3 has issues with Docker and updates, the best next step is to follow the official upgrade guide. It walks through manual update and reinstall options clearly:
If you still cannot upgrade after following this guide, I suggest contacting IceWhale for direct assistance
Thank You very much for the guidance. It worked. I upgraded to v 1.5.0 and then to v 1.5.1. Anyway I did not receive ZimaOS Plus benefits. Hope it will automatically activate since I am using an official Zima device. Is there a way to manually activate Plus version for official Zima devices?
