Zima + pihole + lan cache
i am looking to get lan cache working with pihole on my zima machine to have this ultimate homelab server.
Hey, could you please provide more details about your thoughts/plan? And what workflow/need do you plan this for?
i have pihole setup im just looking to add lan cache without making changes to my pihole docker or changin zima os webui port. trying to install lan cache and use it with pihole as i already have pihole set up
this is from a lancache discord. Short answer: yes
Long answer: you’d be better off adding another IP in the long run, major updates to Zima OS may cause the ports to reset, having a dedicated IP for your pihole (uses 53 (required), 80 and 443 (can be changed)) and LanCache (requires 80 and 443, QuickStart uses 53 as well but with extra elbow grease you can set it up without 53)
I have my server set up with pihole using 81 and 4430 (with required 53) then using LanCache with 80 and 443 and using PiHole to route the DNSMASQ stuff to LanCache and it’s been working golden
can i use 192.168.0.146 still or do i need to change my ip on lan cache to 192.168.0.147 cause i have dual ethernets
