Zima Backups....?
Is there any scheduling available in the Zima Backup app? I can’t seem to find anything. If not, is this going to be implemented in a future release? It seems rather silly that this is not something built into the app. Every major backup app I have used has a scheduling option. If your not using the Zima Backup, what is everyone using for scheduled backups?
Hi, this app Kopia
Great, thanks. I’ll take a look at Kopia.
I installed it but could not get it to work. Are there instructions on how to install it?
Service Unavailable
The application is not running properly. We recommend checking:
All configuration items (e.g., port, path).
The access permissions of the storage directories.
The connection settings for dependent services like the database
