peram
May 4, 2026, 1:52pm
1
I’ve spent a few hours trying to get it to work—no luck.
Neither the ancient version (V13), nor the Legacy (V14), nor the latest (V15)… the documentation is a nightmare, and the link to the forum:
Added WG Easy V15 to BigBearCasaOS - BigBearCasaOS Change Log - Big Bear Community
doesn’t help either…
Let me know if anyone has managed to do this and, more importantly, how?
Thanks!
Yeah… you’re not alone on this one. WG Easy on ZimaOS/CasaOS has been hit-and-miss for a lot of people, especially across V13 > V15.
From what I’ve seen helping others (and testing myself), the issue usually isn’t WireGuard itself, it’s a mix of:
container networking (NAT / port forwarding not lining up)
missing kernel support or permissions on ZimaOS
environment variables not matching the actual network setup
CasaOS UI not exposing everything WG Easy expects
So people end up thinking “it doesn’t work”, when it’s more like “it’s very sensitive to setup”.
What actually works (in real-world setups)
Yes — people have got it working , but almost always when:
they run it via Docker CLI / compose , not just the App Store template
they explicitly set:
correct WG_HOST (your public IP or domain)
correct UDP port (usually 51820)
and most importantly:
router port forwarding is configured properly
Without that last one, it will never connect even if the container is perfect.
Why it feels broken on ZimaOS
ZimaOS adds a couple of quirks:
It’s Docker-first (no full system control like Ubuntu)
Kernel modules (like WireGuard) aren’t always exposed the same way
App templates can be outdated or incomplete (especially V13/V14)
So newer WG Easy versions (V15) can behave inconsistently depending on how they’re launched.
Honest take (so you don’t waste time)
If you’ve already spent a few hours and got nowhere:
It’s probably not you, it’s the stack.
What I’d suggest (non-destructive, realistic path)
You’ve got 2 solid options:
Option 1 — keep pushing WG Easy
but switch to a clean Docker Compose setup
ignore the CasaOS template completely
Option 2 — use something more stable on ZimaOS
plain WireGuard container (no UI)
or something like NetBird / Tailscale (way less friction)
If you want to continue with WG Easy
I can give you a known-working minimal config that’s been reliable on ZimaOS, but I’d want to confirm first:
are you trying to access it from outside your network ?
and do you control your router (for port forwarding)?
That’s the key difference between “it runs” and “it actually works”.
peram
May 5, 2026, 7:55am
3
thanks a lot gelbuilding for your comprehensive reply…
and glad to learn that it’s probably not always me who fails;
I tried tailscale and it works so I could live with that -
although in my “before Zima time” I used wireguard on my old NAS
and got to like its simplicity and full control idea;
so I think I’ll skip “easy”wireguard and try with plain docker CLI/compose
so 2 questions:
any recommendation for a docker compose?
I am on a Wimax network and have no control on the router/antenna, but have to ask the provider to open ports etc. - so I have an open port 51820 pointing to one of the zimblade’s ip-adresses (both ethernet ports are connected to a switch). Does it matter which one it is pointing to?
peram
May 6, 2026, 2:32pm
4
tried it with the linuxserver/wireguard container
just changed
SERVERURL and the volumes section
done in 10 minutes and works like charm - even produces client configs;
