Everytime i turn on my NAS, zimaOS open some random ports.
What’s the purpose of this ports, and how can i close them?
How did you determine this?
Any screenshots are helpful.
I found out that i had UPnP activated on my router and then i turned it off, and since then it’s ok.
Hi, we are careful about your network security.
Please provide this:
The specs of your machine;
The version of your OS;
The detailed steps that you found this result.
Would you reproduce it and take a screen record of it? That’s helpful. Look forward to your feedback.
My OS version is the v1.3.3, and i found this ports on my router opened, and then i saw it happened because the UPnP option was unable. I disable this option and since then, it’s fine.
The ports were linked to this URL: github.com/icewhaletech/icewhale-files (devel)
