Hi,
I wanted to know if the zimaos system recognizes all the drivers of this motherboard please :
W680 NAS Motherboard
Best regards
Hi,
Best regards
Since we don’t have this motherboard on hand for testing, and ZimaOS typically supports drivers for the vast majority of mainstream hardware, I recommend giving it a try. If you encounter any driver compatibility issues, please report them here, and we’ll work on resolving them as soon as possible.
Okay, great.
Thank you for your feedback.![]()
Hello,
Have you had any feedback in the meantime on this W680 NAS motherboard, to find out whether it is fully compatible with 10Gb networks and other features?
Here’s the link to the motherboard (in case it helps):
I look forward to hearing from you.
I took a close look at the 10GB network card used on this motherboard—it’s the AQC113CS—and ZimaOS already supports this network card.
Thank you very much for your feedback
