Visual bug on dashboard
When adding external links on the dashboard they will always remain as “new” despite being clicked multiple times, the system being power cycled and working as intended for days now.
We will try to reproduce it. If there is a problem, it will be fixed. Thanks for the feedback!
Hello, can you send out the docker-compose.yaml file of your two applications, and let’s try to reproduce and troubleshoot the problem?
You can run cat /var/lib/casaos/1/new_app_ids.json on the command line to see if both apps are still in it
They’re running standalone in another VM and in another mini PC. It’s like an URL link and not actually a container.
Yes they were: ["PBS","PVE"]
I just had the file edited and removed those entries leaving only [ ] and now it’s clean. The “New” tag is gone after refreshing ZimaOS page. Thanks for pointing me in the right direction.
Thank you for your feedback, it’s great to fix your issue, and we expect to address this issue in the next release
