Hi,
ZimaOS v1.5.1 App Store Virtual Machine Manager not install
if you select This app it’s try to load but not done.
if you select install button to directly install notify app not found.
Hi,
Hi, to help others understand and respond quickly, please fill out the template below.
Description
Explain what’s happening in simple terms.
Steps to Reproduce
List the exact steps that lead to the issue.
(Screenshots are helpful, videos or screen recordings are even better.)
Expected vs Actual Behavior (optional)
What you expected to happen, and what actually happened.
Before It Happened
Mention any changes or actions performed before the issue appeared.
Troubleshooting Tried
Describe what you’ve already done to fix it.
(Include visuals if possible.)
System Details
Add your hardware specs, ZimaOS version, Zima client version, and Client OS version.
You are suggested to make this permanent: Preferences > Profile > About Me. Recommended format:
ZimaCube | N150 | 64GB | 990 Pro | RTX 2000 | ZimaOS 1.5.1
Thank you for taking the time to include these details, and it helps everyone resolve issues faster and keeps the community running smoothly.
