Used storage not displaying right amount
The used storage display is not changing even if I add or remove files (unless I restart the server). It stuck to 595 GB and my hard drive contains about 750 gb of datas in total.
I am facing the same issue. Hope zima team will fix it with update.
Thanks for the feedback. It is a known issue. And the improvement is on plan.
