Hi everyone,
after working on Disk Monitor, I started another project for ZimaOS: Update Monitor.
The idea came from a problem I had myself: Docker update detection is not always clear enough, especially when containers use tags like latest, fixed versions, different registries or multiple services in one stack.
So I built Update Monitor to make Docker updates easier to understand and manage directly from ZimaOS.
What Update Monitor can do
- Checks installed Docker applications for available updates
- Shows installed and available versions
- Supports fixed versions and following tags like
latest - Individual update policies for each app
- Manual and automatic updates
- Targeted verification after an update
- Backup before updates
- Restore existing backups
- Docker app start, stop and restart functions
- GitHub and Docker Registry version checks
- Supports applications with multiple containers
- Persistent settings and policies
- German and English interface
- Responsive interface for desktop, tablet and phone
Update Monitor also tries to avoid false update notifications. For example, a newer upstream version can still be displayed for information even when an application is intentionally fixed to an older version.
Security
Update Monitor needs access to the Docker socket because it reads Docker information and can perform Docker actions.
Before the first start, please change:
UPDATE_MONITOR_USERNAME
UPDATE_MONITOR_PASSWORD
UPDATE_MONITOR_SESSION_SECRET
The GitHub token is optional.
Current version
v0.3.316
Installation
Update Monitor is now available through my ZimaOS third party App Store:
https://isanto1306.github.io/zima-appstore/store.json
You can also find the source code here:
https://github.com/isanto1306/Update-Monitor
Feedback
This is still a project I am actively developing.
If you find bugs, strange version detection, problems with a specific Docker image or have ideas for improvements, please let me know.
I would especially be interested in tests with different Docker applications and setups.
Thanks!
iSanto1306
