But how is it possible that the Tailscale app available on the official ZimaOs store is version 1.98.3 , which, by the way, also has some well-known security vulnerabilities , instead of the latest version, which is 1.10.4.1, if I’m not mistaken?
Do I need to install it with Docker and download it from somewhere else?
simply edit the image to tailscale/tailscale:latest on the yaml and it will install version 1.104.1 which is the latest.
click the 3 dots to open the settings menu
select manage
click YAML on top right
add :latest to the image line and click save. it will then download the new version.
as you can see from my console I now have installed 1.104.1
I’ve had similar issues in the past with other docker containers. usually doing an uninstall and deleting the tailscale folder from appdata on the zimaos drive followed by a reboot clears up the old install. then install again fresh using custom install option for tailscale in appstore and change the image file on the YAML to latest for a fresh install with the latest version helps.
glad you got it working
