Tailscale not working
Was working fine that it just stopped. I reconfigured from the start but system will not respond to the curl command . Says tailscale does not exist when it try to find it
From your description, it sounds like the Tailscale service may have either stopped running or the binary path was lost during a system update or reconfiguration. When the system says “tailscale does not exist,” it usually means the executable or service link is missing from the path, rather than a network issue.
If possible, please share a few extra details so we can narrow this down:
• Which version of ZimaOS you’re using (for example 1.5.0 or Plus)
• Whether Tailscale was installed from the App Store or manually
• What happens when you try to start it again (any specific error message?)
This information will help confirm whether it’s a missing package, a service crash, or an environment path issue. Once we know that, we can guide you through the quickest recovery step.
