Hi there
after migrating location ( App data, App image )to another harddisk
Taliscale vpn doesn’t work, I didn’t change anything in the app
does any one have an idea why?
Hi there
Please tell me which type of migration you have done?
You can refer to this article:
Also, I’d appreciate your help with this issue
To help others understand and respond quickly, please use the format below when posting an issue.
Description
Explain what’s happening in simple terms.
Steps to Reproduce
List the exact steps that lead to the issue.
(Screenshots are helpful, videos or screen recordings are even better.)
Expected vs Actual Behavior (optional)
What you expected to happen, and what actually happened.
Before It Happened
Mention any changes or actions performed before the issue appeared.
Troubleshooting Tried
Describe what you’ve already done to fix it.
(Include visuals if possible.)
System Details
Add your hardware specs, ZimaOS version, and Client OS version.
(This section will be automatically included in your signature once available.)
Thank you for taking the time to include these details, it helps everyone resolve issues faster and keeps the community running smoothly.
Dear Sir,
thank you for your reply
I solved the probelm by reinstall the tailscale app.
B.R
Ramy
